Left brake light loose?
BlueCollarTahoe
anyone know which way i should go? the left brake light gets loose time to time, should i change out the socket? seems the bulb pushes in pretty well just loosens up after a while
Big Mama
Virginia
Are you using dialectic grease when installing? Also the housing around the bulb base get corroded.
BlueCollarTahoe
BlueCollarTahoe
Only the left?
What happens if you swap bulbs from side to side?
honesty the right one someties blink too but isnt as loose or dim as the left i think i did swap em at one point but im not sure.
not lately but i could use it. if it was corroded it wouldnt work period right? the lighrs before the led was always working.
I just bend the tabs in the socket inward a little bit with a small screwdriver so the bulb goes in nice and snug that usually prevents the bulb coming loose
Big Mama
Virginia
Rust causes bad connections and may work on and off. How long have you had the LED lights? Everything was good before them?
BlueCollarTahoe
BlueCollarTahoe
today i took them out and put in some cheap regular bulbs...were off. i went through the fuses and one of them were blown it seems. i put a new one and the brake lights were back.
05Single
afraid of the dark
I bend the wires out on the bulb itself . Dielectric grease helps.
BlueCollarTahoe
BlueCollarTahoe
can anyone reccomend a good brand of bright LED lights with solid bases to them? it seems the cheap LED light bulbs bought off amazon werent fitting real snug like the cheap bulbs from autozone do. i want the bright LED in all the lights not the old bulbs.
Big Mama
Virginia
If you go to the 2007-2014 forum and type LED in the search there are dozens of pages.
CrackerJack135
