LED taillights Help
CLEAR
So. IN
Just got in my smoked led taillights from ebay. They are the x3 racing ones. I like the look alot but they dont fit so well. They have too much gap at the top and bottom. I can move them up so the top looks nice but then their is a 1/2 inch gap at the bottom. Anyone else notice this or have a fix?
---------- Post added at 09:31 PM ---------- Previous post was at 09:28 PM ----------
not mine but a good pic of the gap
M3PO
Mid West/Cow Town USA
I hate to say it, and I know its not the popular vote around here; but thats why I don't like a lot of the after market stuff. I am fine with looks and that, but not at the sacrifice of function/reliability.
chauncey0337
MLT, WA
Does your gap look exactly like the one you posted? Because the one you posted can be fixed by just loosening the screws and adjusting a little higher. I have the same ones in clear and mine fit just fine.
blueflamed03
Oklahoma
x2, so far why I am still stock.
adrianb
Longview, WA
If they are too small, they are too small. You can't do anything to make them grown.
As you said, you could scoot them all to the top and find some trim piece to fill the bottom, but that sounds pretty ghetto.
I would check with your seller, see if they have any ideas or return them.
IMO the LED add isn't worth it if your truck starts looking like a poorly made patchwork quilt.
2005yukonxl
ours fit perfectly....like kman's above. no gap around ours, they fit like a stock lens would....
not sure if this was the issue or not, but when we ordered the seller said there was a delay because an entire shipment was shipped defective and they had to be re ordered. perhaps they had a bad mold? i'd talk to the seller...no way a light should have that sort of gap around it...
here's ours....ours as well or perhaps better than stock. theres no reason for the gap in that first pic...other than a poorly made light.
aftermarket equipment is great, if its made well. and most of these lights are. its not patchwork anything, i'd even say the poorly fitting LED ones look tons better than the dated poorly designed tri color stock units :)
Sasquatch
Orange County N.Y.
I have the same ones and they fit perfect. Like adrianb said, check with the seller and see if you can get another pair.
Or just return them and buy from a different place.
E4L
I like the LED tail lights anyone no where to get them? Thanks
riso79
So Cal
I am on my second set of them from X3 racing through eBay and did notice a little gap but could even them out and never noticed it again. that top pic could be adjusted out if they tried.
E4L
Richard what did you do to hose plastic pieces behind the back window that looks clean
2005yukonxl
aftermarket.....never expect great alignment...but look good none the less
nothign wrong with expecting great alignment from a quality aftermarket part. its obvious they had some that were made wrong...as in the first pic but my gaps are ever bit as tight as stock ones were.
side note, that one in the top pic, i know its not the OPs truck since he stated so, but that truck appears to have had quarter panel work done on that left quarter panel...looks like the body work isnt great on the lower area below the body line. that could be one issue for that particular truck but since others are saying they had a gap too, then i go back to my earlier sugestion that the OP got some of the defective ones....
lfh2indiana
