LED low beams and fogs
ChevyGirl111
Can anyone recommend which LED lights to buy for 2015 Tahoe? I have been looking on amazon they are called Alla lights, there are so many choices out there. Good and bad reviews. I'd like to hear your opinions and recommendations. I've been currently running Silverstar ZXE's for about a year, one of my fogs just died the other day. Looking to replace both lows and fogs
jerryjoe28
That Guy
cabot AR
ive never heard of Alla lights but if the reviews are good I say try it out. I have used Opt7 100s of times and have had good luck. I literally just swapped my low beams to LED last night. I decided to try some called "Lightening Dark" they had really good reviews and look well made. I don't have enough experience to really give a review on them but they defiantly look well made and are extremely bright
ChevyGirl111
ChevyGirl111
My husband actually just bought and installed some Opt7's for his fog lights today on his truck and they look great! do they last pretty long?
Jason101
I'd like to upgrade to LED for headlamps and fogs in my 2017 Tahoe LT. The stock projection lamps suck. Are these LED upgrades plug and play? Or, do they require additional wiring? Are they really brighter than the stock lights?
What numbers should I be looking for headlamps and Fogs?
Do LED's work in "Low Power" mode for the DRL's that the LT's use?
4armo
Do yourself a favour.. skip the LEDs and install HID low beams. I had LED lows, but the beam dies off way earlier. Install on the HID is a bit longer, but results are well worth it. LEDs are fine for the fogs but the light isn't focused by reflector and just sort of sprays everywhere. More to help you be seen than to produce usable light.
TallHoe 96 OBS
