Led license plate light issues
fatboyracing
So one side of my license plate light flashes on and off sometimes it did not do this with standard bulbs or I did not notice
Any ideas I swapped bulbs left to right and the problem stays on the drivers side so I don't think it is the bulb
NathanJax
Vacation Nathan
Jax, Fl
Loose wire on the connector?
13yukon
Possible cheap/defective. LED. I had the same issue until I switched to Sylvania Zevos
F
fatboyracing
cheap LEDs and is on the way to dying
they are v-led I thought they where a good brand but what is weird is when I move the light to the other side the light works the problem just stays on the drivers side
01Konvict
Boats n Hoes
Raleigh/SML
Take a volt meter to the wires and see if its fluctuating then fix loose wires on back side or trace them to source
NathanJax
Vacation Nathan
Jax, Fl
this
Does the power/ground stay the same or is it going in/out?
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
It is because you do not have the right bulbs.
Dillon2222
I would def. check the wiring. On my Yukon i had found that both bulbs were not working. After testing with a test light and a DMM i had found that i was getting power to the sockets but they were not coming on. After looking at the wiring ( taking the wire cover and electrical tape off) i had found that the ground wire had a bad splice coming from the one ground wire from the harness connector to the two going to the bulb sockets.
Yizzo88
