LED cubes reverse light mod 04 yukon
JustinToolbox
Mooresville , NC
I plan on mounting my led cubes under my bumper an would like to have them wired so they come on when in reverse , off completely , and on when needed . I have the gist of how it needs to be done , but can't find the relay or toggle switch needed to do so .
This is on my 04 yukon by the way .
Any help is appreciated !
nharkey85
Alabama
You need a typical 12v 'normally-open' relay and a double throw switch (on/off/on).
The wiring get a little complicated but i had this done on a toyota years back.
nharkey85
Alabama
I had my switch in the bed of that truck for reference.
- 12v fused from battery to switch.
- 12v from one side of switch to relay behind taillight.
- ground the relay
- tap into factory reverse light circuit
- relay output to led cubes
- 12v from other side of switch back towards relay, but connected to feed going to cubes. You need a diode on this wire to block voltage backfeeding up to switch.
Depending on where you mount your switch and relay determines how much wire you have to run
nharkey85
Alabama
This allows 3 functions.
1. Stock
2. Cubes on in reverse
3. Cubes on when switch is on
Yates_III
Louisville, KY
There are a few posts about this. Check in the exterior page. I found this for you that is a complete walk through (although it's not a Tahoe) it should in theory be the same wiring.
JustinToolbox
JustinToolbox
Mooresville , NC
Good deal . Went an bought the relay and switch . Just waiting on new bumper before I set the cubes up .
I appreciate the info .
jdpber
GOLD MEMBER
The America
i have cubes under my rear bumper and they were the best hour of work i have ever done to the tahoe.
Leno1364
