LED bar behind grill
Fram993
Great idea. Would love to see some photos of the interior switch hook up
Denton
Waco, Texas
I am considering putting a 32" behind my Denali grill, any idea if it would still look decent? Where are yall finding your brackets? Would a 40" be too wide?
cheyenne383
Far North Lurker
Healy, AK and NE GA
Here are mounted pictures of mine, it's a 32" flat two row unit. I put a small lighted switch next to the 4x4 knob on the dash. I wired it separate from the high beams so I can leave it on if I'm working on something in front of the truck. The mounts came with the light and I bought the same company's (NiLight) wiring kit and made some changes to make it work for me.
It lights up great, no issues with it being behind the mesh of the grille. I'll try to take some night shots of the beam pattern and the Hella rocker switch and post up.
cheyenne383
Far North Lurker
Healy, AK and NE GA
Here is the switch, I lined it up centered with the headlight and 4x4 knobs. I hate aftermarket switches, this was the smallest and most subtle I could find.
Here is a close up of the bar lit up, I made sure and marked the mounting area before removed the grill so it shines out of the right area. the opening is right at 32" wide.
Here why I installed the bar, it's dark 18+ hours a day in the winter here...
Low Beams:
High Beams:
Light bar on:
Kenny D
Crosby, Tx
I have pondered this idea. Although I was thinking of using the factory fog light wiring. Does anyone know if the wiring/relay system would be heavy enough for such a lightbar? Pro's and Con's of using this set up?
I had (2) 8' on my 2000 Yukon in place of the factory fogs and it ran off the stock system just fine, but if you think a bigger bar might be to much for it then you can still use the factory switch and just run a relay very easy to do and it takes the stress off the factory system, the relay just makes the factory button a on/off control.
MattGallion
Thinking of doing this and using an on-off-on switch so I can select between On, Off, and On with High Beams. Only issue I'm having is figuring out where I can tap a signal wire from the high beams circuit. Anybody know?
I know I could do an add a fuse to the high beam fuse in the engine fuse panel but I'm not sure if that's the best idea.
sarneson91
Alexandria, VA
I shoved a 42” behind my grill, clears headlights by 1/4”. I put my switches up where the garage door opener unit is, well between it and the lights will post pic in 30 seconds
Denton
Waco, Texas
I just bought a 40" curved and put it on my Civic as a trial run. Will be installing it behind the grill of my Yukon soon. First pic is headlights only, second pic is light bar only.
Denton
Waco, Texas
No, HIDs just turned them on plus windshield is 40% tint
Sent from my SM-G892A using Tapatalk
Denton
Waco, Texas
How long did the install take? I am going to try to install two 40" light bars behind my grill next week. Hoping there is room.
vdesolution
