Leaf Spring rattles
warndogg
What the heck is this called and how do I keep it from rattling around?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
just a leaf spring clip. holds thing straight and tight. are you missing a leaf by any chance. should not be rattling around unless a leaf is missing or it is stretched out.
ezdaar
Chat Troll
Redneck central, Aka Houston
Bicycle tube.
Slice it in 4" section then down the side to make a rubber rectangle.
Remove that part. Slip the section of tube into it. Then reinstall it.
While if off, use a pry bar to seperate the leaf's as much as possible and plce more of the same section of rubber between the leafs where the plastic isolator are.
Trim everything so it doesnt look like crap.
No more rattle.
warndogg
warndogg
Not missing a leaf. Maybe I'll try the bike tire trick. It has been driving me crazy and I can't figure out why that is the only one rattling.
Sent from my XT1080 using Tapatalk
varminpoolteam
