KYB, I'm a fan now!
lamerem
I just changed out my struts and shocks with KYB's Gas-A-Just line. The front came complete with springs, and fully assembled. I have to say I was trying to decided between Bilstein and KYB. It was a tough decision, but I feel good about it. The truck feels like new, and a real pleasure to drive now. If you are trying to decide, I don't think you will be disappointed either way.
Fless
Moderator
People's Republic of Colorado
I am looking at those for the front of my NBS, and will probably will pull the trigger after I get a chance to install the new sway bar links and bushings. Hopefully the bushings and links firm things up a bit. Keepin' the Nivomats on the rears.
Danny3737
I’ve used KYB’s on several of my cars over the years and was never disappointed in any of them.
akbrener
Baltimore, MD
I have the same setup on my 08, Rock auto KYB kit.. definitely an improvement over the 185K mile stock stuff I had on there but they seem to be a bit lacking on rough roads and all the crappy pavement around Philadelphia. perfect setup for 90% of Tahoe/Yukon owners
StatutoryAPE
Peoria, Az
I've got the same ones also. Love them too I've always liked kyb stuff for at least 13 years
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I just put a set of KYB shocks on my 2005 Tahoe. Like night and day difference over the worn out original shocks. I will reserve complete judgement till after I get 10k on them. Even at 68 years old, I drive the crap out of my rig. So far it has not let me down.
91RS
GA
KYB isn’t bad. The Bilsteins are definitely better but they’re also more expensive. I would definitely choose KYB over the junk Dorman, Monroe, Gabriel, and the Arnott passives. The biggest thing people don’t think about is the springs. You probably got more out of having new springs than the new shocks. Quality suspension is priceless.
OR VietVet
Willamette Valley
Agreed, but to me, the biggest thing that makes the difference in handling and can be felt immediately upon the installation, are the sway bar assemblies. That is next in line for me and then some new tires. I know springs make a big difference as well though. Plus, I do agree with your statement, "Quality suspension is priceless".
I used to run shops and I had kids coming in to my shops wanting to go fast and increase performance. I told them I can do engine work and fuel system work and bolt on "cubic dollars" but it is all crap unless the suspension and brakes can handle it all. Some of them understood and addressed my recommendations but some did not and then I saw them after the fact wanting to "increase handling". I think that happened after they got a little "hairy" and pried their ass from the "puckering action" attached to their driver's seat.
Fless
Moderator
Which ones did you get? I have a set of KYB's (KG5040 Gas-A-Just for my Premium Smooth Ride) sitting here waiting for a warm day for install on the front. Sure looking forward to getting them on the rig and testing them. Might do 'em tomorrow since it will be the only warm day for the next couple of weeks.
OR VietVet
Willamette Valley
These for the front: https://www.rockauto.com/en/moreinfo.php?pk=503589&cc=1431156&jsn=1493
These for the rear: https://www.rockauto.com/en/moreinfo.php?pk=503668&cc=1431156&jsn=1495
My plans are to do some more research and get performance front and rear sway bar kits and do the rear springs at the same time.
mmalcolm
Glad i saw this. I have a PPV and need to replace the rear shocks so going to give these a shot to help out the rear ride of the truck. Ive lowered the Tahoe 2/4 and have the shock extensions so just going to keep them in for now with the KYB rear shocks. Will post an update when I get them installed and driving on them
S1W99
Did you finally put these struts on? I have a 2012 LT with the premium smooth ride and new ACDelco OE struts and it's not that smooth. I'm researching trying to figure out what I need to swap them out with.
91RS
GA
If they’re not discontinued.
Fless
Moderator
I did, but mine are not struts, it's a 2004. So a different suspension.
albac
