Ka-thunk
Shrek66
I have a 2004 Yukon XL (SLT) recently I started to notice a ka-thunk sound when going over bumps. The sound is getting more frequent as time goes on.
I crawled underneath the other day and checked my suspension components thinking somthing came loose or broke. I could not find anything there, next the driveshaft and was looking for loose U joints the rear was tight and "looked" good, when I started wiggling the front of the drive shaft I noticed the yoke going into the transfer case had slop in it and made a ka-thunk sound. Just not as loud. Doing searches for related threads I noticed that there is talk of removing the yoke and re-greasing it and it would be ok, others have the yoke being replaced and a nickle plated unit being used. Others say to swap out the U joints also.
Is there a definitive answer? If I swap out the yoke does anyone have a part number of a good one to use? what about U joints? I have read a bout two different greases being used, what would you recommend?
Also is there something in the transfer case that may be bad?
Thanks
dropmech
Puddle Pirate
Coral Springs
Check the security of your spare tire. I was hunting down a similar noise for weeks before I realized my spare was loose.
S
Shrek66
I checked the spare like you suggested. Unfortunately that was not it. I think I am going to pull the driveshaft, grease the yoke's splines and see if that does anything.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
is the noise front or rear? have you checked for broken front stabilizer links?
Bentley95
