I've got a screw loose
Dutchman
Charlotte, NC
Well, not exactly a screw loose (although some might disagree with that), I'm actually missing a screw. Specifically the one in the door panel behind the grip. I have a 2003 Tahoe LT and I was replacing the power window/door lock switch panel and notices I'm missing a screw in the door panel. It's not a big deal, but I'd like to replace it. Does anyone know the specs of that screw so I can find a suitable replacement?
Welcome to the Forum from NH.
Two suggestions:
1) Contact a dealer and purchase the screw from them. It will be ridiculously overpriced, but even if it is $10, it will be a quick and proper replacement.
2) Remove the same screw from the opposite door panel and take it to an auto parts store, and try to match it up with a screw from their miscellaneous fasteners rack.
wjburken
Eastern Iowa
Welcome to the forum from Iowa.
Can you post a picture of where the screw is missing?
Dutchman
Dutchman
Charlotte, NC
It's located behind the handle that you pull on, not the handle that opens the door. I hope that helps.
I didn't think about checking the other door and using that screw. That's probably the best bet. Thanks for the help Joseph!
dizhai
