Is this what i need to retain door chimes and onstar?
Cherdos
Yep just make sure that the headunit you r using is compatiable. Go to crutchfield and see if they have they headunit you plan on installing and it will tell you if or what the piece you need is.
TahoeSSer
A
almightys
I think that is just the steering wheel controls, got that one, but amazon has 30% off some of their PAC stuff
TahoeSSer
I found this Metra site: All you have to do is type in your ride, and it tells you what you need.
Click on Products, then start keying in the make of your ride and it spits out what options you have to order the right unit.
I hope this helps.
http://www.metraonline.com/products.aspx
Ihaveatahoetoo
