Interior lights wont turn off. 98 2dr 2wd need help bad!!
John Ryals
My interior lights wont go out. Have replaced both door switches, cleaned rear door pins and contacts, tested light switch with new switch, roller and button tested on new switch. Looked under dash for light module around steering not sure which it was unhooked all of them no luck. Anybody in this great group have any ideas im lost at this time. Thanks in advance for any help. John
PG01
Up here to the right
Pull the fuse for now. But push on the lights first i think I remember the light lense itself was the switch???Double check them door switches. If not your headlight switch must be bad.
J
John Ryals
Every thing lights up door lights and under dash lights i checked dome light switches first. Door pins are new still on both sets, headlight switch was tried with a new gm switch. Thanks for the reply something crazy going on. Found out after post it had a new headliner put in just before he sold it. As always wasnt a problem but fuse was out! Haha thanks again
WITCH1975
