Interior lighting?
abideejay
20' from the surface of the sun (otherwise known a
I've got a 2005 Yukon XL with most of the bells and whistles. I'm starting to notice that it seems as though some if the various switches, buttons, controls, etc should light up...but don't.
With that being said, is there a definitive list of what should or shouldn't light up? I don't want to start disassembling the truck just to find out that something was never meant to light up in the first place.
I also have a 2001 'Hoe that is in the same condition.
Sent from my iPad using Tapatalk without using real keys, just two fat fingers and a screen.
Donnie Yukonie
Yates Caretaker
well i dont know of a list but post up what you think should light up
abideejay
abideejay
Well, the headlight switch area is dark....
Missing a couple of buttons on the A/C panel...
Window switches are really dim, but I've heard that in the 05 they are SMD LEDs.
Donnie Yukonie
Yates Caretaker
all those should light up fine but if they are burnt out or too dim for you you can switch to LED any color output , IMO best mod ive ever done for the money . there should be write ups/ stickys in your section of all part numbers and steps for this
slipping
Rosamond, CA
Agree. 1st thing I did to my hoe. The wife won't let me touch hers but I wanna do it.
chauncey0337
MLT, WA
The only difference as far as lighting goes is that the 05 doesn't have the footwell lights like the 00-02 does. I think.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
correct but some1 posted up here they had the wire for it which i believe was psyph1
to the original poster you can open the moduals up and solder led bulbs to each and theyll all work we have a member here who does it but i cant think of the exact name
im thinking its :
scottyboy
some1 correct me if im wrong
also replace all domes and map lights while your at it i have a post on which i put in...some followed carcrz but he left out some high output ones so there much more dim
pm me if you want the link bud
DCT
If you have basic soldering skills you can repair all of these yourself. Replacement 12v bulbs are available from Radio Shack. If you want colored LEDs there are websites other members here have used. I replaced the following bulbs (not LED) in my 01 burb.
Climate control panel
Headlight switch
Seat heater switches
Driver side power window switch
OEM Radio were out but opted for an aftermarket radio
Ashtray light (this one is not soldered)
My year does not have steering wheel buttons which typically go out as well. As far as I know, the rest of the interior lights, including the instrument cluster, are not soldered.
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
Hopefully I can borrow the tahoe from the wife this week and drive it to work and do some stuff to it
Buford bubba
