interior door bezel removal
95escahoe
Hello, I have a 95 Tahoe and im going to replace the pass side rear window motor, before the motor went I replaced the bezel I don't wanna break it is there a way to get the bezel off without breaking it? maybe some tips, cause I tried it once before and ended up breaking 2 of the clips off, thanks for the help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Rear Window Glass
82183536
Rear Door Window Sash Channel
82183537
Rear Door Window Weatherstrip
CAUTION: To prevent personal injury, gloves should be worn when removing broken glass .
Lower window
Remove or Disconnect
  1. Trim panel. Refer to Trim Panel. See: Body and Frame\Doors, Hood and Trunk\Doors
  2. Water deflector. Refer to Inner Panel Water Deflector.
  3. Window sash bolts.
  4. Glass weatherstrip. Pull weatherstrip out of window frame and front run channel.
  5. Lift window out of the top of door.
Install or Connect
  1. Slide window into glass channels through the top of door.
  2. Glass weatherstrip.
  3. Window sash bolts. Tighten : Window sash bolts to 1.9 Nm (17 lbs. in.) .
  4. Water deflector. Refer to Inner Panel Water Deflector.
  5. Trim panel. Refer to Trim Panel.
---------- Post added at 06:42 PM ---------- Previous post was at 06:42 PM ----------
Remove and Install
82183534
Rear Door Window Regulator Assembly
Note :The power window motor can not be serviced. It is replaced as a unit with the regulator.
Tool Required : J 34940 Rivet Gun.
  3. Window glass. Refer to Rear Window.
  4. Window sash.
  5. Glass weatherstrip.
  6. Regulator assembly from door.
    1. Drill rivets securing the regulator to door inner panel.
    2. Guide regulator assembly though rear lower hole.
Install or Connect
  1. Regulator assembly to door.
    1. Guide regulator assembly though rear lower hole.
    2. install rivets securing the regulator to the door inner panel using J 34940.
  1. Glass weatherstrip.
  2. Window sash.
phillydog07
Go to youtube, search 1aAuto. Go to their channel and search Chevy Tahoe. There will be a video about removing the door panel. It's for the front, but the part where they show the door handle bezel will be the same.
Would post the link for you, but I'm on my phone.
Sent from my ADR6300 using Tapatalk
briannorris
