Instrument Cluster Gremlins
Austin johnson
Fargo
2003 Yukon, I have had the gauges die all at once for a while. Must be a defective ground Added a ground pigtail to the ground pin that plugs into the back of the instrument cluster. It worked for a few weeks, then gauges stopped again.
Removed the cluster again, removed the ground terminal from the wiring harness, made sure it was clean, reinstalled, again worked for a few weeks.
Sunday I was pulling my boat up a hill, the check engine light came on, no power loss, nothing that I have noticed, not even fuel mileage loss. This morning I put boat in water, pulled out to park truck, gauges are off again, and the DIC reads “RERE” with the truck running, off, key out, doors open, etc.
Been 2 hours, and DIC still shows “rere”. Any one come across this?
2003 Yukon SLT
5.3 flex fuel
Everything is factory
213,000 miles
sgosa
Mine is doing the same thing now. Did you come up with a fix?
rockola1971
Indiana (formerly IL)
Check for silver migration. The solder used on the instrument cluster circuit board has silver in it and it tends to grow nasty stuff that starts to bridge the solder path traces on the board. Search youtube video for silver migration and clean the board. Its an easy fix and likely needs to be done anyway.
BadDaddy2003
