Installing inside fan filter
Woodblocker55
Is there a kit to add a filter to the front fan ?
2006 GMC Yukon XL slt plus.
Sent from my LGL84VL using Tapatalk
Woodblocker55
Woodblocker55
It doesn't have one now I checked. I will have to look for the kit .
DougAMiller
Colorado
I think NBs & nnbs is the same for this one.
That's correct, and I know this one works for NBS because I used it to put a cabin air filter in my 2005 Tahoe. The cabin air filter was not an available factory option that year which is why it doesn't show it as fitting. Dorman started offering one, so GM jumped on the band wagon and made one available too.
Woodblocker55
Woodblocker55
Thanks for all great info . I just changed a cabin filter in my car it's amazing how nasty they get.
Rural areas dust etc . So putting one in Yukon XL is a great deal . Atleast it's made so you can add one.
I will order that ac Delco door for it . Thanks
Steve Waddington
Senior Member
Burbank, CA
I added a cabin filter to my 03 Tahoe. The retro fit kit includes the correct screw too. And the slot that the end of the door fits in is already there. The toughest part is cutting the slot, not much work room...especially if you’re 6’6”! Just go slow and be careful, there’s a condenser in there just to the left of where you’re cutting. After cutting the blank, use a file to smooth the edges. Then, depending on where you live, there might be a bunch of old dead leaf particles, dust, sand... maybe even mold. Clean everything out and make sure to install the filter carefully in the correct position ( the air goes from the passenger side to the driver side).
Good luck.
Sean James
Mountains of Utah
Yup! What Steve said above. Some came with the slot / door and you could just remove and replace new filter. Others have everything there but you have to cut out the plastic, and the new filter will slide right in. It can be somewhat of a jerry-rig process, but it does work on most all. Some have a filter in it that you cannot get out without cutting, some will take a filter, but don't have one in it. It'***** or miss, but either way you can put one in if you are willing to cut the plastic door to do it. Do your homework first, because there is no rhyme or reason to why GM did it this way.
They quit putting filters in because people would not change them out when they got dirty, so they ended up causing stink issues or poor airflow. But then they started putting them in again because people complained they weren’t there.:insane:
TheAutumnWind
ran that number, shows it fits 07-13 nnbs.
03-07 does not show a serviceable filter or filter kit through gm. unless they make one aftermarket.
i have the dorman one installed in my 05 Escalade. Pretty easy to do.
TheAutumnWind
If they made them easier to access people would change them more I'd imagine. I should probably check mine... but Ive got other maintenance items to address first.
Drewphil
