Installing Fog Lights on a 19' LT with no stock fog lights
NJ19LT
New Jersey
Hey All,
My truck did not come with fog lights. However, I was told the wiring was there all I have to do is buy stock fog lights and plug and play. Not sure if this is true or not. However, if that is the easier route I'll do that otherwise I'd like to get some HID fogs in there. Any help is appreciated!
cmatt
The wiring in the cabin mat be present, but I doubt it’s there under the hood or behind the front bumper.
I can help you with where to look for the wiring. I also build a fog lamp harness that gives you factory functionality. PM me for info.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
if it is plug and play and the harness is there you will also need to change the head lamp switch, to the switch that has the fog lamp option. your stock switch will not turn the fogs on and may also need to program bcm to turn on the fog option.
wwiizz
