Installed a SECOND parallel tranny cooler for my Denali today! (Pics Inside)!!
wade
Well, its 100degrees too often here in KY and I tow ALOT of trailers, cars, mowers, etc.... and the tranny reads 220-240degrees on long hauls. I am TIRED of seeing that and the wussy OEM cooler is garbage. I see larger tranny coolers on freakin Ford Contours for gods sake.
So, after hunting the junkyard I found 4 coolers, all off Fords. Seems Ford uses the largest tranny coolers of all makes. I got the largest of the four and bought it for 11 dollars.
It was off a big 350chassis econoVAN.
After some cutting and drilling, I made some cheap brackets to hold the new tranny cooler!
I cut about 4 inches out of the OEM hard line and connected the new 3/8" line to them to run both coolers in-line with another.
ENJOY!!!
All this cost me was $21 with the cooler, extra fluid, and some soft tranny line.
( I have not towed with the new setup yet, but it runs 20degrees cooler already just from daily cruising )
andrew383
indiana
To each there own but i would have just installed a tru cool 40k ...
redemn93
Jupiter, Fl
how did you clean out the cooler before installing? thats the only thing i would be affraid of. one little piece of debris and bye bye tranny. i hate transmissions.
W
wade
Theres a machine shop across my subdivision and my ex-boss works there. He bathed it.
BOSS
The People's A D M I N
Dallas
Tranny fluid is actually a rust inhibitor, flushing it out with a good amount of fluid and some pressure and you're good.
B
redemn93
Jupiter, Fl
B
tip of the day. makes sense since all the working trans ive removed pans from look so nice and new.
AdrienR
