Ink on leather
05Single
afraid of the dark
Well that was cheaper then a divorce:killer:...... budum tissss
Ok im kidding. I've dealt with some pen ink but never sublimation ink, this is weird stuff to deal with. Doesn't fully dry on hard surfaces but doesn't wipe completely off either.
Any tips? Got some on the carpet too :mad3:
05Single
05Single
afraid of the dark
Clean 03 Tahoe , low miles, small dent in hatch, murder, power seats, sun roof, tow package.
05Single
05Single
afraid of the dark
It happened in the parking lot of home Depot . I went back inside to clean my arms and the look on the face of the cashier lady was priceless. I didn't say what happened, I was just calm and only said "it was just an accident, i didnt mean for it to happen" and that I needed to clean up in the bathroom.
In those siruations you gotta mess with people lmao
After i washed up I told her it was just printer ink lol
TxChevyz71
If you haven't already gotten that cleaned up.
I would try not to wipe it off, (as it might dig it deeper intot he leather or carpet) but instead try to blot it get the wet stuff and the majority of it off first.
Since it's on leather I would try something like: Mckees 37 carpet and upholstery cleaner (its very mild) to see if it can get it up. If not progress to something stronger. or you could just go tougher from the start and use an APC like Optimum Power Clean APC.
or Meguiars APC - Meguiars D101. I am not sure if you can buy that over the counter.
With the APC's read the directions and follow them, as the wrong dilution can discolor the leather and or the carpet.
Good luck!
TxChevyz71
I'm betting it will probably mostly come out. Just dont grind it further into the leather and carpet when trying to get the majority of it up.
The carpet should be able to be cleaned with product and an extractor. You could even use a bissell carpet cleaner / steamer. I think that would get that out.
Danny3737
I remember my Mom using hairspray to remove an ink stain off a leather couch. It's worth a shot, but I'd try it in an inconspicuous spot first. I'm not sure how much different printer ink is to regular pen ink. Good luck.
It almost looks like a crime scene in there.
jem556
KY
Try WD-40...I had success on the same color leather seats with blue ink.
TxChevyz71
There are so many different ways to attack a stain like that. Different strokes for different folks. And it really depends on the carpet and stain.
I've used meguiars APC and or a degreaser on a stain. Spray to saturate it, then agitate with a brush. Spray some more APC. Then use a air hose nozzle and spray the carpet at an angle into a microfiber or a terry cloth towel (use the towel to catch it). Then lightly spray some water ( I just lightly mist it) then use my vac to get all of the apc cleaner up) It works wonders and everyone says it's an old school way of cleaning carpets and interiors.
Now people use a Tornador, they are costly at around $180, but the method I described above is free
dubyagee01
The alcohol in the hairspray is what gets it out. Blotting it with a clean rag soaked in rubbing alcohol should remove it. Leather conditioner follow up
Sent from my iPad using Tapatalk Pro
How'd I miss this?! You can try denatured alcohol too. I use that occasionally to clean leather. Also, how about scrubbing bubbles?
08grey
Magic eraser
Sent from my SM-G950U using Tapatalk
05Single
05Single
afraid of the dark
Wow I've been missing notifications on this.
Tried denatured alcohol. Nope
I'll try the apc trick. Might be too late now lol. I just don't even look in the back seat, nobody rides there. Just pisses me off.
79jasper
Anyone try lexol?
If all else fails, get seat covers. Lol
Sent from my SM-G892A using Tapatalk
05Single
05Single
afraid of the dark
Yea still haven't tackled it yet. Worse case at least it's the 40 side instead if the 60 side, much cheaper lol. Get a new drivers side cover at the same time.
97WhiteYukon
I know simplegreen diluted with water worked wonders on random things in my truck. I would try something asap though because the longer it sits the worse it will probably be.
05Single
05Single
afraid of the dark
Thanks , I'll try it out. It's still there, it's still wet and stained at the same time. Sublimation ink is some weird stuff
79jasper
Oxy clean might work too.
Woned2004
