Project Denali
- Joined
- Nov 30, 2016
- Posts
- 148
- Reaction score
- 150
Hey everybody, I'll try to be brief but this is tricky and I really need help! Bought my 2004 Denali and the truck was just totally neglected. However, it's soon to be my daily driver and I need it to be reliable enough to drive.
Anyways, it killed the battery soon after I bought it, but I attributed it to being a bad battery (looked original). My parents bought me an optima red top for Christmas so I replaced it. The next week I came home to another dead battery... I charged up my optima and did a parasitic draw test. The gauge cluster IPC/DIC circuit was drawing almost 180 mA. I ordered a kit and fixed my broken gauges, burnt out lights, and dim PRNDL. With the guages fixed (see my thread on that) I saw no further draw. Next week, the car was dead again.
Yeah this is getting old... figured maybe it was a bad alternator diode this time. Passed the diode test at the parts store and was creating voltage but apparently wasn't charging the battery (however the battery has been on the trickle charger more than in the car at this point). Purchased a reman with a warranty anyways and popped it on. With the battery charged back up I put it in and ran it for a good 25 mins. I then measured battery voltage and let it sit for an hour. The voltage dropped from 12.55 to 12.43 in an hour... I did another parasitic draw test but the meter read 0 mA.
So I unhooked the negative terminal and I'm waiting to mess with it this weekend when I go back home. I'm also bringing my good snap on meter home instead of using my dad's cheapo because I should have at least some parasitic draw for memory settings correct??
I'm stumped, not sure where to go except another parasitic draw test. The only two things I can think of are:
1) Possibly my cluster because although everything else is fixed on it, the only bad thing is that is does nothing with the key on except illuminate the CEL. When the car is started everything comes to life and the "Driver 1" appears. Yet nothing in key on. (Let me know if there's a fix for that)
2) My new optima battery is bad or is somehow draining itself for some reason... or somehow something is drawing power without my knowledge.
Thank you in advance for your help, I'm really stuck and need you guys on this.. the car has been more or less sitting at my house with no action except occasional fuel ups and idling in the driveway to charge the battery.
