Improve Towing
jack2448
I have a 2005 Chevy Suburban LT with Autoride and has the towing package. I have a travel trailer I tow that lowers the rear quite a bit. I am wondering what I can do to improve not only the ride height while towing. Does someone make HD rear air shocks?
992dr
Eastern N.C.
Just curious, I've been pondering doing this as I'll be doing some trans work in the very near future.
Why not just replace the whole assembly with a complete billet assembly instead of replacing some of the parts?
992dr
Eastern N.C.
Harsh as in neck snapping?
Would that be under all conditions of driving or just under WOT?
ezdaar
Chat Troll
Redneck central, Aka Houston
It would be like this...
At all times.
All billet,
Stop sign, vrooooooom bang into second, vroooooooom bang into third.
Vette and billet od,
Stop sign , vrooooooooom shift nice and firm into second, vroooooooom nice and form into third.
Lolz
992dr
Eastern N.C.
At all times.
All billet,
Lolz
Haha, great explanation.
I'll look into both servo and billet OD.
my service sucks
Bruizza
I am thinking of getting a bigger boat. Probably doing this exact upgrade if we decide to pull the trigger.
992dr
Eastern N.C.
From the research I've done, its a good mod regardless. Less wear and tear on the trans = longer happier trans :)
992dr
Eastern N.C.
Haha, I was reading that earlier today.
Its amazing how many write ups there are on this topic.
TowGMC
Wheaton, IL
How heavy is the travel trailer, and what's the tongue weight? Most people who tow travel trailer use a weight distributing setup to properly redistribute the tongue weight rather than just rely on the shocks. Personally I use the Reese Dual-Cam system which is weight distributing and sway control all in one set of parts.
I know with my 6500-6600 lbs of towed weight and 800-900 lbs of tongue weight that the stock self leveling shocks can't ever lift the rear level. But the spring bars of the Reese when set up properly get everything perfectly level then the air shocks just fine tune the final inch or so of height. The bonus is far better towing stability, and no modifications to tow vehicle.
14SWTahoe
Tampa FL
In addition to distribution of weight, the sway control is critical as well especially if towing at highway speeds for long periods. I wouldnt tow anything over 5000lbs without this type of setup.
HeavyHoe03
