Quick q for those with Tahoe and base Yukon hybrids ...
I'm trying to figure out if my tail lights are working properly or if I'm missing something ...
When I look at the tail lights of regular tahoes at night I see them operating as follows:
Upper red: Dim light while driving, bright light when braking
Middle: Reverse
Lower red: Dim while driving, bright when turn signal on
Now as you know the hybrid tails have leds as the top light ... what I am getting on mine is as follows:
Upper red leds: Dim light while driving, bright light when braking
Middle: Reverse
Lower red bulb: Completely off, and only turns on as turn signal.
Basically at night, my lower red doesn't stay dim. This results in very low light output at night because unless I am braking or signaling, the only rear lights that are on are the leds on dim setting and the tiny little side lights.
So I'm not sure if this is how it is meant to be or if I am either using the wrong bulb or wiring setup. I don't think it's the wiring because I have the entire setup, harnesses and all, back to stock.
Anyhoot, if someone can test this for me to let me know if theirs is the same I'd much appreciate it.
Cheers!
Middle: Reverse
Middle: Reverse
Cheers!
