Humming noise when phone is charging and plugged into the aux
Mighty02tahoe
Looking for a little help from anyone who's solved or has any ideas about this issue!
Mighty02tahoe
Mighty02tahoe
The phone has a USB charger plugged in and an aux cord going to the head unit. Have tried different chargers and cables. No change. Is there a faulty ground strap that would cause this. The under the hood ones seem to be good.
bhcbman
Mighty02tahoe
Mighty02tahoe
does it do it with a different phone? does it do it when it is not on the charger?
Yes it does it with other phones. If I plug into a portable charger and not the cigarette lighter port it goes away.
The noise is gone when not charging. Or at least quiet enough that I don't notice it
Is the deck a factory head unit or aftermarket? sounds like you might need that isolator linked above or if it is a aftermarket head unit check your grounds on it maybe relocate the ground to a different place
Mighty02tahoe
Mighty02tahoe
It is aftermarket and I relocated the ground a while back, long before the problem started. I'll check out the isolater, thanks!
ladorn45
That is usually do to a week ground somewhere. if you are only getting engine noise when phone is plugged into charge try getting a better charger. Usually cheap cable will pick up engine noise.
TallHoe 96 OBS
