vjr021
The headliner on the piece that covers my sunroof is starting to fail.
Any ideas on easiest way to fix this?
That's weird. Junkyard time!I purchased an 05 Yukon and the sliding cover your talking about is missing unfortunately
The part I'm scared about (from a bad experience) is using TOO MUCH GLUE!!! Gluing the headliner on a Cherokee - use too much spray, didn't let it dry to tackie, and when I used a rubber spatula to lay it down...the glue soaked thru the material!!! Yes - it's "glued"...but...... I'm almost scared to take it out. LOL
I've had that happen a few times and it sux! Depending on the job, sometimes I go a little heavy , but not crazy , spraying the glue on the board, and then spray lightly on the material itself. Wait at least 5 mins if not a little more , for it to tack up nice, then with nice even pressure smooth it out. I like to use those plastic little spatula type things body shops use to spread bondo on with. I usually do sections of headliner that have fallen down, not complete headliners. As you're smoothing it out with the spatula, make sure you don't have any wrinkles in there.The part I'm scared about (from a bad experience) is using TOO MUCH GLUE!!! Gluing the headliner on a Cherokee - use too much spray, didn't let it dry to tackie, and when I used a rubber spatula to lay it down...the glue soaked thru the material!!! Yes - it's "glued"...but...
