Ya, I jacked it up. It's not really that I messed with anything in the suspension, ie. shocks or springs, and the arms don't hold pressure, just keeps axle inline. But you can't really get to anything when your already LOW!!! Just lifted up vehicle, and removed trailing arms, added brackets, reinstalled. Pretty simple. Probably could be done on ground, but made my life easier jacking up, just took longer to jack up on stands then to add the brackets!! I also reinstalled my coil isolators last night. Thanks Toni(NorCal SS) it made the noise stop.
Hey Toni(NorCal SS) I am hearing a popping noise every now and then on certain bumps. Seemed like when I reinstalled the T-arms, the driver side made a popping noise when I retightened them. What would cause that? Could I have gotten a bolt thread caught up, or something? I had to remove the whole t-arm to get it to move off axle mount, and when I retightened the bolt on frame mount, it started popping when tightening. Should I remove and reinstall? Thanks
