how to install an air bag clock spring??
odie301
Kasson, MN
ok, a long time ago i took the intermediate steering shaft off to get the grease back to the top. during that process, the steering wheel spun and the air bag clock spring broke.
So, since the wife is pregnant, and she now drives the tahoe because she lost her job and just runs errands...i am now putting in a new clock springs. I bought a used steering column ($150)..took my old clock spring out, put the one from the used steering column and installed it today. Started up the truck and just wiggled the wheel and POP! this one busted...i am thinking it was maybe sorta messed up from the junk yard(maybe had been spun just shy of breaking?)....but no warranty on electrical parts from the junk yard...SOOO by stroke of luck i found one on Ebay for $100....this one is BRAND NEW with the little clip that prevents it from unwinding. so extra money that i didn't want to spend..but still cheaper than the 400 new the dealership wanted.
SO anyone know the correct procedure to install one? I just want to make sure that i don't have to spin my steering shaft to a certain position, in case that matters?
anyones help would be appreciated.
hassoun
Germantown, MD
send me your truck's specific details and i'll pull the instructions for ya using my alldatapro membership access.
O
odie301
Kasson, MN
it is a 2004 chevy tahoe lt, flex fuel. the original part number for the clockspring was 26102329...and i just so happened to get the same one off of ebay. The truck has the steering wheel controls and dual plug air bag.
let me know if you need anything else like the vin?? thanks for the help
hassoun
Germantown, MD
this is the closest thing i was able to find. Let me know if you need any other instructions. i couldnt find anything about clocks spring but i assume u're trying to install the air bag module on the steering wheel ?
1. Position the inflatable restraint module to the steering wheel.
2. Connect the electrical connectors to the inflatable restraint steering wheel module.
3. Connect the CPA retainers into the electrical connectors. Seat and lock the connections.
4. Position the alignment posts of the inflatable restraint module to the holes that are located on the steering wheel housing.
5. Push the inflatable restraint module into the steering wheel in order to engage and in order to latch the 2 leaf spring fasteners (1).
6. After installation, pull the sides of the inflatable restraint module in order to ensure that both leaf spring fasteners are engaged.
7. Enable the inflatable restraint steering wheel module. Refer to SIR Disabling and Enabling Zone 3
Big Jim
