How Much Clearance?
98blackbell
FL
This is the rubber stopper on the lower front control arm. How much clearance is it suppose to have? Should I cut, remove or buy a new shorter one?
Have dropped spindles and 2" lowered springs on the front!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
More then that.:)
If the suspension was untouched from factory ( we can allow dropped spindle here) You would want this:
Vehicle Ride (Trim) Height Specifications
42162403
Vehicle Ride Height Location & Specifications
Work it as bet as you can.
---------- Post added at 12:09 PM ---------- Previous post was at 12:08 PM ----------
You are not going to get ideal clearance unless you put stock springs back in.
AtomicHoe094
Atomichoe094
cleveland, OH
you can unbolt it and buy DJM ones if you want. id just try cutting it at first and see how it rides. lowered trucks will almost always ride like doodoo
98blackbell
98blackbell
FL
Tks comit and sunlit. Ride is what it is. About the same to me. 2dr ride stok sucked any ways. I was just trying figure out what factory spacing would be. I know I am getting travel cause large bumps undsr speed the front air dam botfoms out. So that rubber stopper has to be being smashed.
AtomicHoe094
Atomichoe094
cleveland, OH
heres the djm ones on my tahoe
5/7ish drop. cant tell you if they bottom out yet (havnt had the truck on the road much this summer) but maybe you should stiffen up the front shocks as well
98blackbell
98blackbell
FL
I have the DJM flip kit, with the c notch. I used the cal max shocks as well.
98blackbell
98blackbell
FL
I did cut it in half. Started with an air saw. Just made smoke. Then sawz saw, same thing. Went to a cut off wheel that did the trick.
Diference in hard cornering. Before it would porpoise off of the stop. On way to work have a corner getting ocf the 417 onto the 528 that you can go at 65 mph
patniven
