How low can I go without rubbing????
NAPLES_TAHOE
Naples, FL
I want to run 24" wheels. Which drop combo is the safest to go with where I won't have to trim or hammer on anything. What size tire is safe?
I know if I stay with a 22" wheel, the 305/40-22 seems to be a popular size.
Thanks!!!
Sent via Tapatalk.
Clean07Burb
Here's my experience if you do decide on 22's...
I'm down 2/3 with 22" CK375 rep's on 305/40/22 Toyo Proxes STII's and I rub the front inside edge of the rear liners under moderate rear suspension travel and the fronts just BARELY rub on both sides at full steering lock. I could probably massage the front liners using a heat gun and eliminate that. I hate rubbing, so when it comes time to replace my current tires, I'll more than likely go with 285/45/22's, which I believe would not rub at all.
NathanJax
Vacation Nathan
Jax, Fl
This about sums it up. Even with a 2/3 you will likely get a little rub if you don't bend or cut a little something out of the way.
NORCAL SS
SUV SUSPENSION GURU
all you ened to do is trim rear plastic and front do my fenderwell 2x4 mod
24x10
305 35 24
3/5 drop
mine is fine and my wife drivers it daily. Id go wtih 295 35 24 if you want more clearance
Stanm5
24x10
305 35 24
3/5 drop
What's the 2x4 mod? I've got rubbing.
Stan
NathanJax
Vacation Nathan
Jax, Fl
Stan
In a nutshell, you take a 2x4 and bend the metal behind the wheel back. If that's where you're rubbing, there's almost an inch of metal you can move
NORCAL SS
SUV SUSPENSION GURU
yes and turn the tire and let it suck the 2x4 in. This will clearance it back
mfinta
