How can i go bigger?
Tahoe_99
I want to get a bigger more aggressive looking tire, but im not sure how much bigger i can go. right now i have 245/75/16 on it. would getting a 4" lift help? and if so how much more space would it give me?
T
Tahoe_99
Really? im just worried about rubbing if i go bigger with it stock, but im not sure what the best lift to get would be to create the space i'm looking for at a relatively decent price. Any suggestions?
T
Tahoe_99
ok. because i looked at discount tire and their website said that the biggest that could fit would be 275/70/16. But Im also thinking about possibly to an 18" wheel, do you know what the biggest size tire i could get with no problems there?
KPOD
Michigan
I think total wheel diameter is the limiting factor, rather than what the actual rim size is.
T
Tahoe_99
I was looking at that and discount tire sells Nitto terra grappplers that i might be interested in at 285/60/18. Wouldnt that fit just as good as 285/75/16?
KPOD
Michigan
If you're gonna go with an 18" rim, I think you'd want at least 35" tires or bigger, or else your ride quality will suffer sine you hardly have any rubber.
T
Tahoe_99
that makes sense, but 35" tires wont fit on a stock tahoe will they?
Indiana
you can body lift 3" for about $250 and it will fit 33's with no rub unless youve got the suspension flexing. and for the price, mickey thompson baja atz are some bad ass tires. the a/t look like m/t and the m/t look like super swampers lol. check em out. or toyo open countrys.
and i had 18" eagle alloy offroad rims with 33" mickey thompson baja atz i think they were lt205/60/r18 and never had any problems on pavement or in the mud. it was a great set up.
La rabona
Houston Tx
tires
if the truck is 4x4 u should be able to fit 285/75/16 with no issues at all even 305s ,4x4 is an inch higher then the 2wd i believe .....i run 285s ,
048tahoe
