Hose from filler neck to gas tank leak (I think)
Gunpowderboy
The other day while pumping gas I noticed it starting to spill out from under the car right by the spare tire.
I have had the filler neck replaced ("re-manufactured" from some exhaust piping) so it's not that. I dropped the spare and the condition of the hose leading from the filler neck to the tank is questionable but I didn't find any holes. Since it's a 2002 and I was not the first owner I'm unsure if one of the previous owners have made a quick fix. What should the hose leading from the filler neck look like?
Mine looks like it's two pieces of hose with a metal piece in between right by a beam that runs across the car in-front of the spare. Is this correct?
If it is correct would a fix involve more than unscrewing some hose clamps and exchanging the hoses and the metal bit?
If this isn't correct what is involved is this a do it yourself type of thing (with very limited resources as I am on the road across the US right now) or a shop thing?
Do you see any problems to continue driving with it for now (given that the gas would have to be pumped low and slow)?
Thanks for any help!
jkhuntzinger
