High Pitched Noise from Front
tmt502
Greenville, SC
Hey all, I've been trying to look for threads/posts related to this, but can't seem to find a match.
When I first get in the truck for the day and depress the brake pedal to shift into gear, I normally hear a high pitched squeal, before I even shift. The noise sounds like it's right in front of the dash, where the master cylinder would be. It normally continues while I'm moving the shifter and seems to dissipate after a few seconds. Maybe lasts two to five seconds. After that first time, it doesn't make an appearance until the truck has been sitting for a while, I'm guessing long enough for everything to cool off.
Is this the master cylinder going bad? Or a leak somewhere?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
The squeal is likely the first signs of a brake booster starting to leak vacuum. If the squeal/squeak is constant and then eventually dies out, that is my best guess. If the squeak is just when depressing the brake pedal, then I believe the pivot point of the pedal needs some lube.
tmt502
tmt502
Greenville, SC
It is a constant squeal that fades out. Definitely not a squeak from the brake pedal.
OR VietVet
Willamette Valley
Then now is the time to get a mechanic's stethoscope, some come with horn attachments to help with some noises, and find the location. Your guess at the noise location was pointing me to the booster or brake pedal.
tmt502
tmt502
Greenville, SC
Thanks, I'll look into doing that.
Strangely enough, when I started up yesterday, I depressed the brake pedal to shift into gear and.....no noise. I don't get it. I'll see if it's back today. Would a vacuum leak be temperature dependent? The weather is a bit cooler now.
ihtblzr
Did you ever figure it out?
MasterHank
I have had the same thing, happened just yesterday lasted about 4-7 seconds usually when I just shift into gear, I will check the cap on the cylinder and look for visible leaks
and advise, It has happened 4-5 over the last 3 years.
also had an issue with the windshield wipers not working, Wife had taken the truck out called 10 minutes later in a panic said they would not work but the lights would turn on and off
read a few posts people changed a board etc
the solution I found was turn on the lights all the way from off to on with the engine running then turn on the wipers then it reset itself.
also had an issue where the door locks would lock unlock while I was driving again people changed control boards, but the failsafe with this truck when the remote battery is weak it auto unlocks so you can drive the truck disengages the anti theft.
SuburbanPassion95
