Hid color different or same??
Gron86
like the title says, what does everyone think? Do the HID lights look the same or is one slightly different? (Talking about color temp.)
Thanks
from a photo they look they same, but photos of lights don't really show the full spectrum, its best to check by the eyeball at night from a slight distance. like park in the street at night turn them on and walk ahead about 50-60 feet and then turn around and look at them
G
Gron86
Thanks, is it normal for hid lights to be slightly different colors? I also think the projector affects the light spectrum from different angles.
Looking at them straight on at night the color is almost identical.
However if the Truck is moving (looking from another car in front though mirror) the light on the passenger side seems to shift color and looks less bright.
But like I said looking at it straight ahead with naked eye. Lights look almost identical.
G
Gron86
To me, the dtiver side looks whiter.
Yes that’s what I see too. At certain angles at night.
I’m going to try to get the pass side lamp replaced under warranty.
But at this point I might as well replace them both.
I have had some projectors do that before which is part of the reason I don't like them, from one angle they will look the same and from another angle be different
Vanquish Auto
202 Wallace Ave N Unit 12 Lehigh Acres FL 33971
Thanks
Hello. In my opinion you have the same color in both sides. Nice white and bright .Sometimes while driving you may think and sometimes you really know because you can see one side seems brighter than other and sometimes is the way of the bulbs has been located(inserted) I have some customers that they have purchased out bulbs because the ones they had previously from other cup pliers where giving them this same type of issue., and we have find out is the way the bulb locks in place., if you want you can check on that and see if it fix the problem., if not I will recommend you to get a different kit or probably just trying to se wit it is licked all they way fix it.
Thanks
G
Gron86
Thanks
Never thought of bulb placement, , I will look into that.
These are oem hid bulbs that come standard on the Yukon Denali.
Nyc2011Denali
