Hi all fixing up my 2003 tahoe - Window switch issue
Wilk 2003 tahoe
I just replaced my left rear window regulator and new switch for rear door, I have full control from the driver master panel up/down but from the new switch in rear door only goes down ? Bad new switch? What else should I look for?
Test the new switch with an Ohm meter, to be sure that it is not the cause of your issue.
SnowBuck
Heard a slight clicking from the RR door. Stopped when I disconnected the switch. As a quick & simple test you can just temporarily install it on the other side and visa versa. I found I had a bad RR switch...$15 on Amazon. Wondered just what can make a window switch go bad ?!?!?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to your first post at the forum.
Like @SnowBuck said, swap switches and see what happens. Please tell us you did not use a Dorman product for the regulator and switch.
HeavyHoe03
