Help with headrest monitors
w84no1
I bought the PAC GMRVD so I could hook up 2 headrest monitors for the 3rd row. Everything works, but there is swirls and faint lines in the video on the headrest monitors and the RSE flip down. If I unplug the video from the headrest monitors the RSE video becomes crystal clear. So, do I need a video amp? If so, what are your recommendations.
Thanks,
w84no1
G4rr3tt9
Idaho
I'm tagging along because I am getting ready to do a headrest install and want to learn anything I can about this subject. Good luck.
SmallXL
Any power wires near your video feed? Could be interference from crossing lines...
W
w84no1
No, there is only the video wire connected to the harness. Even if the headrest monitors power is disconnected I get swirls in the RSE monitor. If I remove the video wire, then the RSE clears right up. I just don't think the factory head unit has enough power to send video to more than one screen.
BLKTXDenali
A*TX
This might sound dumb but ive seen alot of crazy stuff, u r using video wire right? Some people use regular audio cables works a little bit can't carry it fast enough to make good quality, On top of that ya I think a video amp will make all the problems go away just take ur sources straight it first then branch off from there.
W
w84no1
That is not a dumb question, but yes I am using a video cable. I have used differently shielded cables and it is the same problem. I guess I will be buying a video amp. I have never bought a video amp, is there anything that I should be looking for feature wise? I have found a couple of 1 to 4 video distribution amps, but I don't know what specs to look for.
AdrienR
