Help needed! Multiple cylinder misfire and traction light
Cfouts28
So I’ve got a 2007 Yukon Denali, 6.2 liter, truck was driving fine, then a few weeks ago my wife got off the highway, comes to a stop on the exit ramp. Goes to start going again and the truck immediately started to have a catastrophic misfire. Engine light flashing, traction/ stabilitrac light comes on, truck violently shaking. She turns it off right away. Highway is only like a mile from my house so I went and limped it home. Could smell raw gas real bad. It was incredibly underpowered and started smoking from under the hood. Popped the hood at home and the smoke was from the drivers side cat just cooking.
So things I’ve done, removed the cat to see if a clog caused the misfire, this wasn’t it.
Replaced all the coils, seems to be a little better but by no means fixed it.
Plugs and wires are probably a couple years old, but my wife puts like 5k miles a year on the truck, so I’m assuming those are fine.
Not sure where to turn from here
Geotrash
Dave
Richmond, VA
Need to read the codes or we're all just guessing. Get a Bluedriver dongle because you can read all of the modules with it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yes! Codes! Please!
For what it's worth, I had something like that happen once with my 05 Z71 and needed oxygen sensors.
As stated above, the codes are needed for proper issue diagnosis and least expensive repairs.
ScottyBoy
Shreveport, La
Sounds like you may have lost an engine ground. You might have lost the ground for the coils and fuel injector harness. That would explain all your symptoms....
BadDaddy2003
