hec.deli '05 Denali Build
hec.deli
Newb as you all can tell. I am pretty new to it all but ultimately I would like to start keeping record of my time with my Denali. I first picked it up back in 2007 as a one owner vehicle with around 45k miles. Please feel free to comment with recommendations or comments. Here are some of the modifications I have done over the years and future ones I am planning on doing:
6192ab7a-18c7-4ea9-9845-8eb7fb910492
(I'll put more pictures after I've cleaned up a bit, kind of embarrasing how its sitting after being used by the wife and kids for a few months...)
Current Milage: 166k
Exterior Mods:
-Moog Front End Suspension (Lower/Upper Ball Joints, Upper/Outer Tie Rods, Idler Arm, Idler Arm Bracket Assembly, Pitman Arm, Camber Bolt Kit)
-Front/Rear Belltech Street Performance Shocks
-Belltech Leveling 2/3-4" Kit
-DJM Enlinks
-Air Lift 1000 Air Spring Kit
-Black Front & Rear "GMC" Emblem
-Xentec 6000k HID Low/High Beam & Fog Light 55W Conversion Kit
-Spyder Auto Chrome CCFL Halo Projector Headlights
-Energy Suspension Front Control Arm Bushings
-Energy Suspension Complete Front Sway Bar & Endlink Bushings
-Energy Suspension Rear Control Arm & Track Rod Bushings
-Energy Suspension Rear Sway Bar Bushings
-5% Window Tint / 70% Windshield UV Package
-Sylvania ZEVO LED 6000k lighting
Pending:
-Rough Country Steering Stabilizer
-Energy Suspension Body Mount & Radiator Support Bushings
-24" Yukon Denali Replicas
-Full Paint
Interior Mods:
-Tan Leather / Black Woodgrain Steering Wheel with Controls
-BMW (77-02) Floor Mat Lock Kit Carpet Retainers (Pg. 2)
-Tan Lloyd Mats Floor Mats with "Denali" Logo Embroidery
-Complete Sylvania ZEVO LED 6000k lighting
Performance:
-K&N 57 Series FIPK 57-3050 Air Intake
-MSD Super Conductor Spark Plug Wire Set
Pending:
-MSD Pro Power Coils
-Magnaflow 15734 Cat-Back Exhaust System
Audio:
-iSimple Bluetooth Interface ISGM655
-XS Power BIG3XP
-OPTIMA Yellow Top D34/78 AGM
-JL Audio XB-BTU Battery Post Terminals
-Upgraded DVD Player Ground
Maintenance:
-Replaced Water Pump / Thermostat - 132k
-Replaced All Hoses - 132k
-Replaced Coolant Reservoir - 132k
-Replaced Front/Back Brakes & Rotors - (80k/166k)/136k
-Replaced Transmission - 55k
-Replaced Radiator - 55k/145k
-Complete Suspension Make Over - 136k
-All other regularly conducted preventative maintenance (flushes, greasing, etc.)
Motor Oil: AMSOIL XL 5W-30 Synthetic Motor Oil (changed every 6k miles)
-All other fluids AMSOIL (Automatic Transmission, Differential, Brake, Power steering, Transfer Case)
-AMSOIL greases for lubrication points
05Single
afraid of the dark
Sounds great but the image isn't pulling up
hec.deli
hec.deli
Haha I've been trying to figure out how to edit it, for some reason the link disappeared...
Fosscore
List looks good. Looking forward to the pics.
hec.deli
hec.deli
Does anyone know why I cannot edit my thread post? I can for all the others ones...
hec.deli
hec.deli
*Coming soon!
-SphonAdjustable Panhard Bar
-Belltech 2/3-4 Kit
-DJM Rear Sway Bar Endlink Kit
-Belltech Street Performance Shocks
-Air Lift 1000 Air Helper Springs
Hopefully by then I will be out of "Newbie" status and be able to make changes to my original post. If not they will be added to regular feed.
fiatdale
Houstons Best
Houston
Good start, good list. Ditch the K&N sticker on the rear window. It does nothing for such a good looking vehicle.
hec.deli
hec.deli
Haha yeah it'll be coming off here soon. You definitely make a good point there kind sir.
hec.deli
hec.deli
Yay finally out of TYF Newbie status!
brian.roberts.1293
Durham NC
What are the BMW mat holders? As I need something to hold down my weather tech mats. The little screw down thing they sent sucks.
from my Galaxy S7 Edge
hec.deli
hec.deli
This is what they look like... You can find them on eBay in many different sizes and types, but the ones in the picture seem to hold the best and are the ones I am using. You'll have to cut a hole into the mats, the two circular pieces connect to each other creating a seal which allows you to use the other piece to set them in place, screwing into the carpet. I would send you a picture of my setup but currently I am unable. I think they are a very good investment for the type of mats I have, keeping them in place very well. I am not so certain how they will do with a mat made of a rubber material though, but it would be something to look into.
hec.deli
hec.deli
Deconstruction complete. Parts prepped and waiting for paint.
briannorris
