Heated/Cooled Seat Switch Question
wjburken
Eastern Iowa
So.....My daughter pointed out that the section of the heated seat switch assembly on the passenger side door that has the three indicator lights in it is loose and pops out a little when the door is shut. Any one experience this? If I have to swap it, is it something that needs to be programmed to the vehicle or is it plug-n-play?
wjburken
wjburken
Eastern Iowa
Don't know about the programming but the mounting ears could be broken off behind the panel.
That’s what I figured was the case as well. I need to pull the door panel when it warms up anyways to replace the outside door handle in that door, so I’ll take a peak at it then.
Buford bubba
