Bcox
I have a 2003 z71. My problem exists with both air conditioning and heat. I hope I can explain it to where it makes sense....
As i'm driving the heat/air (depending on winter or summer) will be fine, then it just cuts off. Still blows a little but not at the setting its set on. If I turn it off completely and wait a couple minutes and turn it back on it works again. I have had the blower motor replaced and that didn't fix the problem. Mine has the digital AC/Heat climate control on the dash. No one seems to know what the problem is. Someone said heating core, but it happens with both the AC and heat. It will just stop working but still kind of blow, I will turn the system off, wait a couple minutes then turn it back on and it works again. I just repeat the process....Anyone know whats up?
