Headlights
juggjiggler69
Can anyone tell me wat is a good set and where to get them and also wat is really the difference between 35watt and 55 watt ballast for hids thanks in advance
Sent from my Galaxy Nexus using Xparent Red Tapatalk
baldd86
Stick to 35w 55w will hotter ad glare more. You can cheap or expensive. There are a lot of brands
Sent from my SPH-D700 using Tapatalk
Ryan1126
DDM Tuning!!!! 35 watt kit will be fine, i have had both 35 and 55 watt and the 35 watt is more than enough and the blue shows more.
Gzes
the drifting 2dr
Wichita tx
Bro I got 35 hids and they are eBay ones and work great. Also have eBay Halos and eBay everything in the front lol. U also need a relay if getting hids
juggjiggler69
juggjiggler69
Ok on the hids but where is a good place to get replacement lenses and the place i got my hids from hsd to upgrade me to the 55w cause of all the power issues im having even after installing the relay harness so i hope the 55w isnt to bad
gordo89
illinois
What power issues were you having? I had an issue with my HID kit as well... But i didnt run a relay yet... Possibly narrowing down what could be a common issue.
juggjiggler69
juggjiggler69
I was having the issue of only one bulb coming on but the relay harness did not help and they reccomended that i use 55w ballast instead without the harness so im waiting for them to get here
baldd86
You had a bad ballast if only one bulb was working right and had a hardness. A good brand of hids that I have heard great about is spencers,the guy sales an economy version and high end version. The eco is like 70 to 90 (I don't recall the price). The higher end is 150. Ddm is like a ebay kit where you hit and miss, sometimes you get lucky and they great, others times they suck.
gordo89
illinois
Let me know how that works out for you, i was having the same problems and thought it was just a bad kit, swapped kits with a friend and it did the same thing. They were both 35w kits. Whatever was causing my issue, it wasnt killing the kits it just wouldnt work on my tahoe. My friend still has my kit up and running
juggjiggler69
juggjiggler69
I ordered a $120 kit and now with the upgrade to 50w ballast i am at like $160 but i talked to the guy today where i got them and he said for tahoes,pick ups,and other trucks he reccomended the 50w kit cause of issues with the 35w ones in larger vehicles,and he told me to take my relay harness back out and that the 50w ballast wont fry my factory wires since the ballast still runs cooler then the halogen bulb,he said he has the 50w kit in his silverado for over a year and no issues so i guess i will hook them up and try it and the kit i have is from euro effects
SuburbanPassion95
