Headlamp condensation
D--k
12 yukon with the noted gm fishtank style headlamps... what's the best on resealing material to use... this is the second set of lamps
houstontaylor
My 2003 Tahoe running lights were filling with water from spraying up behind them from the front tires when going through water (and not condensation). I dried them out and then wrapped duct tape around the electrical penetrations at the rear and that stopped it but I got tired of redoing that and got new LED running light assemblies. So far so good. The same may apply to headlights.
t_bergman
Chicago
Are yours OEM or aftermarket? Aftermarket you may need a new housing as it's almost impossible to find.
The light connections also need to be tight.
brice715
