Grille painted......finally!
Narco
Atlanta
what kind of bumper cover do you have on there? will the oem fog lights fit in those cut outs?
TEXAS DEMON
with a vengeance
texas
you can tell the difference quick. it ties everything together. looks awsome.
NoPh33rRaCiNg
Kent, WA
looks good, any issues with painting on that chrome? just have to sand the hell out of it before paint
Narco
Atlanta
^^ thats what i want to know. what kind of prep is needed to paint that chrome oem grill shell. it'd be a hell of a lot cheaper than buying a new grille shell from SS i was looking at
dblover1327
Denver
aren' those "chrome grills" have chrome paint on them or are they chrome? i wanted to paint my chrome one but wasn't sure
Narco
Atlanta
can someone give us a step by step "how to" for painting the stock grille shell?
ecordell
CordellDesigns.com
Merica
Step-by-step is to remove the grill, prep the surface well (sanding, primer, and final prep) and then shoot it, clear it and if it's "orange peel" looking; wet-sand it. If you wet sand it you'll need to buff it (by hand, not orbital buffer cause you'll easily burn through the clear and maybe the paint) and final glaze it and you're done. No wax for probably 30 days or so......
NoPh33rRaCiNg
Kent, WA
what would this cost to get done professionally?
i was quoted 100 bucks
thank you
rockymt21
wing addict
from the slums of shaolin
Here's a few tips,
Sand the shit out of it. Paint won't want to stick to that "chrome" surface. Apply each coat very thin, this essential for the paint to dry properly and for the durability to hold up. Once it has been primed, check for any drips or anything that sticks out, wet sand whatever you find until it's gone and clean with soap and water before painting. Apply the paint in thin, even coats, take your time it will be worth it. There's nothing worse than getting anxious on that last coat and getting a nice paint run. Let the paint sit for a couple of hours before you clear it and follow the same thin, even coat rule. I would let it sit over night to fully dry and handle it carefully the next day. Give it another day before you wax it up.
ecordell
CordellDesigns.com
Merica
Here's a few tips,
1. Sand the shit out of it.
2. Once it has been primed......clean with soap and water before painting.
3. Apply the paint in thin, even coats, take your time it will be worth it.
4. Give it another day before you wax it up.
1. A must
2. DO NOT clean it with soap and water, user thinner or prepsol and do not saturate the wrags you are cleaning it with, you do not want to soak the piece you want to clean it.
3. Once again "a must"
4. Don't wax it for about a month, you want to let the paint and the clear cure thuroughly.
rockymt21
wing addict
1. A must
I have used dish soap and it works fine. And I really don't think a month is necessary for the paint to cure... This is just from my experience though....
JeffK
