KMeloney
- Joined
- May 2, 2009
- Posts
- 3,460
- Reaction score
- 709
Haha! Fair enough.
Just one more thing...
(Kidding!)
Thanks.
(Kidding!)
Thanks.
KMeloney - for what's it's worth, I'm on the 2/4 (no spacer) w/ 24s and 305/35s. Links are at 3 in. I didn't cut bump stop brackets and I've never bottomed (or come close from what I've felt). I'm rubbing a bit, but that's my biggest "issue" w/ the current setup.
Thanks Josh! Don't let Tony see this next question... What's your rear fender height, before and after the compressor airs up?
And how would you describe your ride?
Thanks!
His tires are different will sit higher
2nd ride is different hes running 35 series
i give up man on the ride. Ive done so many of these trucks the ride is perfectly fine on 285 45 22 and no spacer with links set at 3 inches.
DID YOU PULL THE SPACER OUT YET?
While Tony is entertaining questions though: Tony - any ideas how I could drop another inch (no more than that) w/ the current setup (2/4 - no spacer on 24s w/ 305/35, links at 3in)?
Tony, what, exactly, are autoride resistors? ...
