Fuel trim live data
Tim10
Hi, everyone
Doing some live data on fuel trims my 2016 Tahoe
and I see that long fuel trim bank 1 is negative -10.2
when idle, once I increase RPM to 2500 it gets better around -3%
From reading on a forums and google it tells me that it runs rich. Should I be checking deeper and what’s your suggestion guys?
BG1988
Hi, everyone
negative is less fuel command
positive is more fuel command
generally it should be about zero
short term idle should be 0 (±0.8)
long term idle 3 to 5
vacuum leak or faulty MAF.. or leaky fuel injector(s)
i would clean the MAF ONLY USE MAF cleaner let it dry before putting it back on
recommend disconnecting the battery before servicing
HiHoeSilver
Away!
Chicago
Hi, everyone
How's your air filter?
ynot411
