Fuel Pump Access Door
Bombsquad85
Northern VA
I saw a few times people were trying to find a good way to change their fuel pumps. While browsing YouTube like I always do u found this.
This is not my video, maybe it's someone here if it is I apologize if you didn't want to share it (but if you didn't want that why make the video...)
Anyways I did this on my Tahoe (minus the fiberglass, but I'm going to do it this way on my Yukon) and it makes it so much easier and faster.
Enjoy!
Enjoy!
He did a really nice job, super informative.
Bombsquad85
Bombsquad85
Northern VA
Agreed I've never dabbled with fiberglass before but I feel like this is a easy first time project.
I need to replace my fuel pressure sensor that you see on top of the pump assembly.
I'll be giving this a shot in the next couple months
fiatdale
Houstons Best
Houston
There’s a right way and a half assed way. The time spent on making the fiberglass, making the cut & removing seat and carpet without messing anything else up is time that could have been spent doing it the right way and dropping the tank. I’ve done several of them and it’s really not a bad job even doing on the ground. Right way vs short cuts... right way wins every time.
Agreed. It’s not that hard to drop the tank and you’ll probably only do it once anyway. It’s not like you need to change fuel pumps when you do spark plugs.
Bombsquad85
Bombsquad85
Northern VA
Eh you are entitled to your opinion. However, I find this easier than dropping the tank. With my luck my pump would shit the bed on me when it's full and I have a bad back so working under the car lifting something that heavy isn't a good idea for me. This way makes future changes (I would do it now to do the pressure sensor) easier
fiatdale
Houstons Best
Houston
Understood about your back, I too have a terrible back. But cutting a huge hole in your floorboard for access and then never having messed with fiberglass before could and probably will turn into disaster. You’re better off having a friend give you a hand in dropping the tank than doing the above.
fiatdale
Houstons Best
Houston
Other reason being, if that lock ring is seized to the pump, which depending on how old and how many miles it has on it (highly likely) you will never get the leverage you need to get that lock ring off. Trust me, I’ve done many of these. Just trying to help you out from cutting a hole In your floor.
HiHoeSilver
Away!
Chicago
My thoughts exactly. If I didn't have a giant screwdriver and about 3 ft to SWING a decent hammer, mine wound not have come off.
Yes the angle for getting that ring off from a hole in the floor seems to be not good to me. Then when I reinstalled mine I had to really push down and hit it with a bf hammer. My tank was almost full and I’m an old bastard so I just siphoned the gas out and put it in my other vehicles. No struggling. By the time I would have cut the hole my tank was out.
SnowDrifter
Sasquatch Country
I have to ask... How often are you guys chewing through fuel pumps that you need to cut an access door? Dropping the tank ain't that hard
Bombsquad85
Bombsquad85
Northern VA
Like I said I cut a hole in my Tahoe and there was nothing negative about it. I had plenty of leverage to get the lock ring on and off with nothing other than a hammer and screwdriver.
I can understand why someone wouldn't want to cut the floor. But it's no different than all of these other vehicles out there with access panels.
As for never dealing with fiberglass before. I haven't, however, this seems like an easy enough first project. And if I screw up on the fiberglass then I'll hold off on making my cut.
I think this is much easier for what I need it for. Right now I just need to replace the pressure sensor. This is why I will be cutting the hole. Because I know in less than 50k I'll probably have to get back in there to change the fuel pump. And where I do itll be a 20 min job. And it won't matter how much fuel is in the tank.
The only difference I'll make with my fiberglass panel is go make side I can take it off without having to remove the seats.
Also this will give me an excuse to deep clea. Under the seats lol
SnowDrifter
Sasquatch Country
Actually it is different. Vehicles with access holes are done properly from the factory. Folks who cut their own holes seldom go through the effort of appropriately resealing all the bare metal they just exposed. It's not an upgrade, it's a hack. Want to get cheeky and do it "right"?
Get a sheet of 1/8" stainless, toss some sound deadening on it, cut hole in floor, drill holes and install threaded rivets. Apply some butyl rubber to the crevice of a seal (can't remember the type but it's similar to a door seal), mash it in and around the hole you just cut, then secure the plate you cut out with some galvanized or stainless hardware.
Edit: Found the seal https://www.amazon.com/Black-large-height-0-656-Height-0-178/dp/B00BFWUZ2K
Do as you want of course but I just replaced my fuel pump module for about $120 which included the pump, pressure sensor ( actually never heard of that), fuel pressure regulator etc. I see no need to do one part at a time; do it once and be done for another 150 k miles. It took me all of 2-3 hours and was fairly easy. And my truck isn’t left with a battle scar hidden under the carpet. I don’t expect to ever have to do it again. I considered cutting a hole because I was led to believe that dropping the tank was a ***** but I found out that’s not so. I’m glad I didn’t now.
SnowDrifter
Sasquatch Country
It's only a pain when it's full of gas lol. Take off the filler neck and siphon with a hose. Unless you just filled it up, nothing should come out. Once you get the tank empty, it doesn't weigh more than about 60-70lbs
Bombsquad85
Bombsquad85
Northern VA
Who's being cheeky? I simply posted a video I found interesting and that might appeal to people that dont want to or can't crawl under their truck and drop the tank.
You came in and started talking it down.
With proper sealing and covering there will be no issue with it. If you dont like it that's awesome I appreciate you're inside and the link. But no need to talk it down or tell me I'm being cheeky.
SnowDrifter
Sasquatch Country
1. Wasn't calling you cheeky. It's the idea of doing such a thing properly when it goes against popular vote.
2. It's a public forum. We share our opinions. Mine is that hacking apart your truck to avoid undoing 2 tie straps is risky and ill conceived. I'm not a dick. Don't get on the defensive. You don't need to play victim when I share my opinion as you, yours.
We are all just sharing opinions and different ways of doing things here. Some prefer cutting an access door, and if that's what you'd prefer, that's a perfectly legitimate way of doing it. Some prefer dropping the tank, and that is also a perfectly legitimate way. This is a great place to discuss both ways and the pros and cons of both. Everybody has opinions, and sometimes it feels personal when we share one way of doing things and it meets with resistance but that does not mean that way is wrong or should not be discussed. It just means that there's others who would prefer not to do it like that. Thank God we have this forum to discuss this, so others who come along later and read it can have the information needed to make an informed decision. It's way better than the alternative method I have seen on another subject, bagged vehicles, where there is no longer an active forum to discuss issues and they all use a Facebook group. It's terrible; the same questions get asked over and over because there's no way to search and the information just gets lost due to the format, which results in people getting trash talked all the time and called idiots. I love this forum and the respect we all show each other here.
Bombsquad85
Bombsquad85
Northern VA
I'm not on the defense. At the end of the day it's my truck and my back. If this helps me or someone else it was worth posting.
It's not risky if care is taken to do it correctly. And it's not a hack job unless the person makes it that
latvius
Ariton Alabama
I cut out an access panel on my Tahoe, cut out a new piece of sheet metal, hammered it to shape. Blind rivets are a good idea, once I buy the tool I may go back and do a better job. I used that black gooey stuff used for firewalls as the sealer. It never quite dries but is real sticky. I think I also used sound deadner sheets as well around the exposed area.
Also - my advice is use a brass punch not a steel screwdriver. Brass does not produce sparks, I am lucky enough to have an 18" long one. It was a little challenging to get a good swing from inside the cab but not a big deal.
I would agree you will not change your fuel pump every 6 months but if your troubleshooting something it is nice to be able to look at the pump/connections as they sit.
I also would say change the wording from "hack" to "mod". If someone deletes their rear wiper is it a hack job or a mod? To me a hack job it something done poorly not weather GM intended it to be done or not.
JasonW4141
