Front HVAC not functioning
Brad Route
For the past month or so I haven't used my 2007 Yukon's HVAC system. It's been very mild weather. Now, however it's getting cold, and windows are getting frosty and fogging up. On my way to work the other day I attempted to turn on my front defrost to kill the fog on my windshield, only to realize that my front blower is not putting out any air. I kicked on the auxiliary and the back works just fine. After researching this I was adamant that the issue is the blower motor resistor. I took the stock Bosch one out and tested it with a multimeter and it seemed ok. I decided to buy a new one anyways. I installed it and still no airflow. So now, I'm thinking a bad blower motor. Before I invest 100s of dollars on this part, is there any way to test it to see if it's actually bad? Also, are there other things I need to be looking at as well? I'm at 230,000, trying to get to 300,000 but I don't know if she's going to make it. lol Thanks
Yea and I did check the 40a fuse for the blower motor under the hood. Visually and with a fluke.
Trey Hardy
Mines got over 300,000 now keep the oil changed regularly
I had to replace my blower motor already along with the door actuator now I have to replace the temp door as the driver side is blowing hot all the time and it’s very aggravating if your doing it yourself and got the time order online it’ll be cheaper and it’s not too hard to replace just awkward to get to
Moderator
People's Republic of Colorado
By saying "not putting out any air" do you mean that the blower isn't turning at all? Or that it's turning and there seems to be some kind of constipation?
Disconnect the blower motor pigtail and connect it to a 12v source that can supply a few amps. It should run on that, since that's what the High setting does.
Trey Hardy
Does anyone have the part number for the temperature door actuator or whatever it is called? My driver side is stuck on heat and it’s starting to warm up so some ac would be nice! I’ve been trying to find it on advance but don’t know what it’s called
Eickybobby5050
