front drive shaft for 4.88 gears.
bjballar41
bjballar41
thanks for the find i thought i saw a drive shaft on their site. here are the numbers i could get for u sorry if they are not correct
shocks didnt have a maker on them only thing i found was made in mexico 008375 and under it it said 657341.
front def had this on it 2563 on one part and then looked like j54 thats all i could tell.
bjballar41
bjballar41
im gonna say yes it is a rough country kit and i did find it on the front shock. since this is the gfs daily she mentioned rancho shocks but i looked at them and they are like 100 bucks apiece so no way on that. as far as im concerned id like something a lil softer seems like these are really stiff with no give.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there are different ranchos around. I am not lifted but I use Edelbrock Performer IAS shocks. They cost $90 each The part numbers from rough can not be searched for it turns out you will have to call them to get dimentional specs. They might not be typical maker part numbers in order to get you to buy only from them.
bjballar41
bjballar41
well when i put in how much lift i have 4wd all that stuff they only have one on their site that will "work" with mine same for rough country too for the shocks. im gonna keep looking around tho see whats out there. idk how soon i should change them gf says dont worry about it but they have some cracking at the top where the metal goes in the shock.
---------- Post added at 11:43 PM ---------- Previous post was at 11:37 PM ----------
ill take some more pics for yall tomorrow of suspension stuff to show u exactly what im talking about.
gregsb
Liverpool NY
I keep learning so much from this site.
For those that have the non autotrac systems do you notice any vibrations in 4wd at highway speeds? The reason I ask is that I snowmobile and when winter hits that is when I do lot of traveling.
96ProCompTahoe
IN
haven't had any problems with mine but i don't leave it in 4wd at highway speeds. if you REALLY need for it to be in 4wd you DON"T need to be doing 55mph+ in it IMO. :Handshake:
gregsb
Liverpool NY
Very true regarding highway speeds. I am very conservative driving during the winter.
My last 4 trucks were leased GMC sierras with the newer autotrac so I used to just leave them in auto for the winter. It just has been a while since I ran a part time system. I just want to make sure that if the roads are slushy/slippery I can engage the 4wd and leave it engaged with no issues.
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
I am going to post my setup so you guys can see what Im running.
---------- Post added at 10:05 AM ---------- Previous post was at 09:57 AM ----------
This is the driveshaft I am running. It is a double cardan U joint assy and I had it custom made at my local Driveshaft shop. You NEED this in order to run 4x4 on our AutoCrap equipped 'Hoes. If you have any technical questions, you can also PM me. BTW, we got identical hoes!!! I dont understand why you want to remove the bodylift!?!?
bjballar41
bjballar41
custom ran exhaust? and i havent fully decided gonna wait till i get the nurf bars to see how it is and see how it looks with different tires.
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Thank you guys!!!
It has a Trailmaster 6" Suspension and a Performance Accessories 3" Body lift with gap guards. I am running 35x12.50's Mud Terrians on Mickey Thompson Classic II's 15" rims.
bjballar41
bjballar41
ok two more questions did u swap the trans out? for something bigger? and can i get a full side shot so i can see the tires?
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
It has a fully built 4L60E and a rebuilt NP246 Tcase. I am sorry I had to take 2 shots but I didnt have enough room in my garage and I couldnt pull the truck outside. If you have any other questions, lemme know!!!
Korbin_A
