Front differential. Rebuild or replace
Dan2002
Hi.
I noticed a leak on my 2002 GMC Yukon Denali coming from the axle seal.
I was going to fully check it when I was home. Because I was arriving at work at that time I saw the leak.
After I got off work I headed home but 10 before I arrived home I heard kind of a rubbing noise coming from the front.
It was like my axles were grinding.
I got home and lifted it up. And decided to remove the front differential drain bolt. When I removed it. It had a lot of metal and dirt on the magnetic top on the bolt.
Now I know there is something seriously wrong with my front differential.
Is it better to replace it with a used one or rebuild it?
Also found a guy online that has a 2004 Cadillac Escalade. And is selling the front differential for a fair price. But I don't know if it's compatible with my 2002 GMC Yukon Denali
Metal chunks or powder like from an etch-a-sketch? If the latter, such is normal. What exactly is grinding though?
I'm of mind to rebuild what I have. Some are of mind to replace with a used unit, as it can be less expensive and done faster; if there's nothing wrong with it.
ivin74
05 NBS Nali
Htown, Texas
Hi.
If you plan on keeping it over a year rebuild it or replace it with a new one. If you plan on driving it for a couple of months find a good used one. I have heard horror storys on the junk yard used differentials (they don't last long). Keep in mind very little folks know how to rebuild these diffs correctly. There is a tread some where on the TYF on how to rebuild them your self for a fraction of the cost of a new one or a used one.
D
Dan2002
It is like powder mixed with gear oil. I felt it with my fingers and didn't feel any metal chunks
SnowDrifter
Sasquatch Country
Fill it up and see how it's doing. If all is well, the axle shaft seal is a pretty straight forward job.
I bought mine with a bad front diff and kept close tabs on it. Fairly linear increase in nose and metallic particulate until absolute EOL, at which point both grew rather exponentially.
Would have liked to rebuild it, but the front diffs on these things are a pain in the ass to do on account of the case splitting sideways. If you have the tools and the know how, it's a cheaper option and the quality of work is what you make it. I opted for a reman unit as the investment in tools for me to take on such a task was fairly close to the break even point for a swap over.
Is your rig awd or 4wd?
D
Dan2002
It's AWD
CountryBoy19
Southern Indiana
I think I saw most of your questions answered except this one. You need to make sure it's the same gear ratio. Look on the RPO codes in the glovebox, GU_ & GT_ codes are the gear ratios. GT4 is 3.73 & GT5 is 4.10 but I think the AWDs had lower ratios so yours should be GU_
Make sure it matches his. That would be a GOOD indicator that they are the same but NOT the whole story. IF his or yours was ever swapped for another ratio (not likely, but it does happen) then code in the glovebox means NOTHING and you need to verify ratios by turning the input shaft and counting how many revolutions are needed to make 1 complete revolution of the output shaft.
D
Dan2002
Just checked and it says GT4
D
Dan2002
Update:
I was going to fill it back up and see what it does. But after starting to fill it. I noticed more metal pieces coming out the drain hole. They were very fine pieces of metal. Nothing too bag. So I just decided to take the front differential. Out.
Managed to get it out. And I opened it up and didn't see any signs on chiped teeth on any gear. I did noticed it has 2 bearings on each side. Both look like they have a little bit play on them. I'm not sure if that's normal.
But definitely one of them looks like it has been burnt or is peeling. It has very fine metal pieces coming out the bearings.
I will have to replace both bearings and I would say it's good to put back together.
D
Dan2002
After further inspection of the front differential. I was cleaning all the grease and dirt. And found a piece of metal inside. I took out the drivers side axle seal and found where it belongs. I don't know if this will affect it. And should replace it or continue to rebuild
06JET
Wisconsin
That is the tab that holds the adjusting nut in place. What probably happened is it broke off and let the adjusting nut back out just a little and that is what caused the damage to the bearing. It can be fixed.
D
Dan2002
Do you have a suggestion how to fix this. And thank you for the reply.
Erickk120
I'm not too familar with ifs's as I'm with solid axles. Looks like the tabs that hold the carrier bearing preload in place broke/felloff, not sure how they are held. You probably lost preload causing loosened backlash and likely some whine. Check to see if you have pinion play. If it has some resistance to turn it and if its tight/zero play in and out up and down. It means its in good shape. As long as the bearings werent pitted from metallic fluid flowing in the oil. What did the oil look like when drained?
Here are the options
You can dismantle it and inspect the pinion bearings, if they aren't pitted and look fine you can get away with just buying new carrier bearings and adjust the backlash and carrier preload and call it good as new.
Before getting ahead of my self, you would need a dial indicator pretty cheap at harbor and a beam style torque wrench, to measure the pinion preload. Also a new crush sleeve and seal would be nice while at it. About 130 dollars in part and oil. If you go this route please record the current pinion preload to set it at the same preload or close to as spec as per used bearings.
Buy a new/used unit if it can be found within your budget.
There are plenty of guides online for these units, as long as the pinion bearings aren't toast you have a good shot at building it without having to mess with pinion shims. Its when you need new pinion bearings that messing with pinion depth can get you in a world of trouble. So just check the state of the pinion bearings before hand, and record what rotational preload it had with the beam wrench.
Erickk120
This is the tab, you can get them at the dealer too.
https://www.amazon.com/Yukon-YSPSA-009-Bearing-Adjuster-Differential/dp/B00EHN4D7M
Just realized the actual spanner to tighten the carrier bearings is like 70 bucks, so that came out of nowhere.
https://www.walmart.com/ip/Yukon-Ge...MIl8Tjs6-_4AIVC77ACh1edQfREAQYAyABEgLMkvD_BwE
I guess you can use something else or make your own tool, but not sure about your level of ingenuity.
Although considering just one adjuster has moved, I would try to get the same OE bearings probably timkens, and install the races and press the bearings into the carrier and bolt the case together, tighten the adjuster that loosened, then check backlash and hopefully you get lucky and the backlash is within spec. if not you will have to adjust the other one depending if you need more or less backlash. then you tighten them both tight not sure about spec but can be looked up.
The only challenge I see here is having a tool to move the dang adjusters if you need to.
06JET
Wisconsin
If it were me, I would do just this part of Erickk120's advice. I bet your pinion bearing is OK and it is just the carrier bearings that need to be changed. This would be the most cost effective easiest fix. Others would say that you would be crazy to just do this and everything should be changed and it needs a total rebuild. They would have a point but in that case I would just buy one with a warranty or mileage guarantee and install it my self.
D
Dan2002
Thank you for the reply guys.!
I have checked all bearings and they all seem in good condition. Also the yoke is in good condition no play in it at all.
I will try to buy the parts soon and see if I can get it to specs
