For those who are blown...
foreverfalcon40
What gauges should I be running...
Boost Gauge (in my A Pillar)
Wideband 02
Tranny Temp
Volts Gauge
EGT? I had to have one in my Turbo'd DSM...but now we are talkin Whipple. If I do need an EGT where do I mount it. On the DSM there was a spot for it on my Manifold which is the Header...but now I have two headers.
I just finished up piecing and painting my Escalade Center Console. I am going to build a box on an angle to house these gauges.
bai78
Surviving
Dallas, TX
I personally run a vacuum/boost, fuel pressure, & wideband on my A pillar pod. They are all Autometer Cobalt digital gauges. My scangauge II handles my transmission temp, IAT's (which I relocated from the filter to just before the TB), ECT, MAP, tranny line pressure, & a few others. It is a good little gauge to have especially since you can program the xgauge feature to add things.
Do yourself a HUGE favor & do a 12200411 pcm swap. It's easy as hell & you'll wonder why you didn't do it sooner because it was sooooOOOOO easy.
foreverfalcon40
foreverfalcon40
Ok..OK...
Well Bai as you know on the other forum..due to economy I lost hours at my Mod/extra cash job. The trade off is I have a day off to do things.
Yes Autometer Cobalt Series is the BEST ONE b/c it matches blue LEDS. Of course I'm going digital too it just looks cooler.
You have FP bc you have Marine?
bai78
Surviving
Dallas, TX
The FP was to be in conjunction with the wO2. Fuel pressure, bad pump, etc...needed to be ruled out as a possible symptom of going lean in boost.
I know about the shop & all from the other posts....the 411 is straight forward. Acquire pcm, let Justin retune, manually repin, splice 4 wires, plug n' play.
mfinta
