Flush antifreeze
02Lightning
I would like to flush the antifreeze in the Yukon but without a radiator cap how would I get the antifreeze back in the system? Would I just pour it in to the overflow? Also is there a bleed valve or something if I have to pour it into the overflow?
07whitetahoe
Best bet to avoid air locks, have it vac'ed out at a reputable shop. The cap on the reserve is the radiator cap, but these are easy to get air locks but just draining and filling.
stevek
Dallas, TX
^Air will blow it's way out and the reservoir will drain and fill the air space. Make sure to check after your first few drives that you have enough coolant in the overflow.
---------- Post added at 10:42 AM ---------- Previous post was at 10:41 AM ----------
Oh, make sure you turn the car off with your heater on
02Lightning
02Lightning
You know I haven’t even had the cap off of the reservoir tank, but if I remember it just looks like a regular cap. These systems would have to be sealed and pressurized with a pressure valve somewhere (like a regular radiator cap), then when the systems cools it would suck fluid out of the reservoir back into the system. So I’m not so sure just pouring the antifreeze in the coolant reservoir to fill the whole system would work.
D Rollins
