Fiberglass Fenders
BlizzardX23
BlizzardX23
Sacramento, California
not exactly...you put so much wear on your outter sidewall tread...that is what side to side rotation is for...Im talking about diving into corners...not alignment&camber
yes...when I get new tires..I want 375s in the rear :)
G35 2007
rolling fenders is actually rolling the lip in and pushing the fender out a little you can also use a bat and a heat gun it works great, I did it on my G.
BOSS
The People's A D M I N
Dallas
Get new bumpstops, 2005 Z71 4x4 bumpstops
B
matt14
san leandro,ca
Pretty sure if your offset on your rims. Im running the same size and brand tires that you are and dont have any rubbing on the fender. Im also running a 3/5 drop and my tires sit inside the fender a lot more then yours. Here is a pic i just took.
It may help by turning your t-bar keys up. If you try and sit 3" up front you may not rub.
---------- Post added at 08:17 PM ---------- Previous post was at 08:16 PM ----------
That last pic is horrible. The reason it looks like so much gap is cause my driveway has a slight slope to it, but you get the point.
BlizzardX23
BlizzardX23
I was gonna say..it looks like yours is sitting a little bit higher...also, you looks like you might have a little more negative camber (although, that may not be true..I dont know)
but I like the flush look...I cant stand when the fender hangs out so much further then the outside of the tire/rim
and again, it only happens when I dive the front end down and turn at higher speeds...
---------- Post added at 08:30 PM ---------- Previous post was at 08:28 PM ----------
B
didnt even think about that....thats a good idea...I wonder what the difference is?
CKendrick
